Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
As expected, didn't even hear them :(
A warranty claim just came over my desk though:
Complaint: Vehicle getting stuck in park
Cause: Buying an auto Wiring problem to shift lock release
Correction: Repaired wiring in circuit.
lolfarkin
Work over, and Marisa has just made plans with another friend of hers who is thinking of having a baby, so she's coming over to help with the babies and spend the night to see what night feeds are like
Boo Yaa, getting on it tonight
laps of happiness were good, plenty of open track :)
smity!!!! video!!:thumbsup:
Yeah, been playing cricket all day, will try and get something up tonight.
My CONSULT logger f**ked up so I'll only have GPS data to overlay :(
Did you like my demonstration of epic clutch slip as I went past you? It is completely gone - I couldn't get power down anywhere, in any gear, at any revs :(. Was pretty much limited to 20% throttle.
Had fun following you for a while though, and was still able to catch the pack when I opened up some clear air earlier on :)
New clutch time!
Not having much luck with wheels/tyres either. The front left on my track wheels is losing pressure again as well.
yeah i heard that, clutches often help :) was wondering what was going on there, and where you took off to in such a hurry. hope cricket was worth it, and look forward to seeing the vid.
Lots of happy happiness at happy laps. :thumbsup:
Was something wrong with the chair? Saw you going pretty slow and then you were off track early.
Found myself a busted rear main
Bummer :(
we lost but it was a decent game, didn't get our arses kicked.
I got a duck :(
Video sound is TERRIBLE :(. Stoopid gopro.
it was the one that got away
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
