Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Nissan is 114.3
the only one you will be able to manage is the last option, and it will almost certainly have to be custom.
The only way you can change from 4 to 5 is to keep the PCD the same (e.g. 4x114.3 to 5x114.3, which I think you can get without going custom).
If you want to change the PCD, you need to keep the number of studs the same.
Sonofabitch... so I'd need one of these http://www.vollks.com.au/index.php?main_page=product_info&cPath=192_210&products_id=3149 to change the number of studs, then another adapter to go from 5 x 130 to 5 x 114.3 ?
...SD spec spacer thickness by the time it's done :(
Also dodgy as f*ck...
Guy on the 31 club did it, 4-5 stud converters and then 5x114.3 to 5x120 or something. So not cool. Funniest thing is he bought the wheels brand new, and they were available in a perfect offset and stud pattern so that he wouldn't have needed ANY spacers. He just ordered completely the wrong thing. :P
nah, if your talking VW which it seems. go see Sherman conversions on the gold coast, he can sort you out with any stud pattern you like, drilled off fresh rotors or drums (not so sure on the drums)
this way you can avoid pushing your offset out further than it already is (which in a beetle is already way to far standard :angry:)
my brothers Bug has a set of commo pursuities on it.....:whistling: but he got his as a kit from the states, all wheel disk brakes and all that shiney new car jazz, in the stud pattern of his choice.
Porsche is also more expensive, as the studs are apparently entirely different to any other car and cost a small fortune.
*and dropped spindles are the way :worship:
Ooooo, now this sounds promising. So does that mean I can get away without a hub conversion? I'd like to put newer VW rims on an older one, so getting it to 5x100 would be the one I'm most keen on.
Have been looking at drop spindles, but they look pretty costly :(
have to be custom made from 2 sets of standard spindles.
So not sure of the exact price but you've got to find a second set of spindles, and then pay for the custom job. So not cheap.
gaids :(
spindles check out the whole web site man...silly cheap prices. whole disc brake + spindle kits for less than 500 bucks........seems a bit too cheap
cheaper than chips apparently, only just found this site. never knew it existed before.
as for the Beetle 5-4 stud, not sure how that goes for just swapping rotors. normally this is only a by-product of upgrading your brakes on an old one. and all disc brake bugs are 4 stud. so discs are def the way to go as it will prob only cost a little more, Sherman will be able to help you either way. give him a call, he'll be able to sort you out.
I need drop spindles for the Alfa. Also expensive :(
My brother has his old alfa sitting around.....been ignored since he did the head gasket in it (again) and got the liner. not sure what it is, ill ask him
Been perusing Vollks for the past few days. Some cool stuff there! Already looking at interior bits and pieces, because I bet that will be needed.
Pretty much set on a super, as I think I've hooked myself on that blower idea :wub: so discs will already be the go on the front. Just want more choice for wheels.
ewwww super :sick:, but yay for discs. yeah man, with the super you should just be able to get new rotors and drums drilled to suit whatever you like.
supers also have coilovers on the front, not this silly torsion bar nonsense. which costs alot more to lower and fiddle with.
There's nothing wrong with supers! Especially when you want to modify a bug but don't want to hurt an older one :)
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
