Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
What needs to be done?
HT setup is now working like a boss
well..... i got an intercooler and a bunch of random pipes off Joe (guy in the burgundy R33 at the meeting on thursday night). from what i can see there is a pretty well full set of piping there.
I'm straightening out the bent fins in the front of the cooler, fitting it all. then painting the whole lot satin black with black silicone fittings to blend it all in under the bonnet :) so basically everything, and painting :rolleyes:
Morning Mangs,
Double RDO this week. Another death in the industry yesterday. :( Union will be looking for an even shorter week now.
Morning Mangs,
Cup bet placed. Going on my theory that the favourite never wins, I didn't put anything on Americain
Sounds too much like hard work :P
Morning Mangs,
Going to be weird walking past that building at uni now.
Morning Mangs,
Except for when Mkaybe Diva was a favorite 2 years in a row and took them both home :P but she is a pretty special case.
betting is fine at work. Their firewall is terrible/non existant. Boxed 6 horses for the trifecta. Hopefully it comes off.
Exception that proves the rule :P. Won't happen again for decades ;)
Mourayan was scratched! What is this sh*t? Might box up a trifecta to spend that money....
Or a way to lose it :nyaanyaa:
I cannot lose. It is unpossible.
The race that bankrupts the nation.
An assortment of incompetent politicians have already done that.
i wonder what will get more coverage today,
The Cup or the RBA decision
Cup, hands down.
A way to win enough money to buy a sim cockpit?
apparently normal race meets are far easier to win on than the cup! Most of the hardcore punters I know wont go near the cup.
The 31 boys at tafe bite real well when you ask them how's their pintara running :thumbsup:
Good form, keep it up :thumbsup:
Probably true
Probably true
Too many good horses apparently, at the smaller meets there is normally one or two horses that are head and shoulders above the rest. One of our mates is a horse trainer by trade, the bastard won $6500 one night while we were out drinking, even on a bad week he will make about $1000 out of betting because he knows all the trainers and horses. At least he pays for drinks when he is winning like that so I cant hate him too much!
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
