Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Sounds a bit harsh reading that back but having the day off does nothing for the guy or his family. If they wanted to show respect or help out they should have worked and donated an hour or 2 of their pay to the family to help them out. But like I said they're just looking for another day off after the melbourne cup.
Agree 100%. They loose a days pay, may as well organise it so they work and get paid 75% and the other 25% goes to the family. Would be worth at least several months pay to the family. Much better way to show respect.
When I was in my teens I worked for my dad as a sparky's apprentice. I had the weird position if seeing both the union and the employee sides of any dispute, made me dislike how unions operate, but I admire why they are trying to fight the good fight.
unions and lawyers, all tarred with the same brush. They would have you believe they are working for you but the pricks have their own agendas,
Do not believe the lies:
This clutch will not install itself, no matter how much encouragement you give it :(
mine has this same pic on the back......still sitting in the shelf downstairs.
Morning Mangs,
Have to work late tonight :(, so may be late for ike's cream.
When are you ever on time?
Guys ended up going back to work at 9:30 this morning after the union f**ked around for 3 hours lol.
haha no i wont but there is alot of helpful hints for other areas of your 'romantic' life!!
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
    • Toasty! I was around the same. Around 50 but with a fuel cooler. Got my tuner to dial down the pumps and its so much better.. i think last time I drove it was around 35-40 during summer. PWM makes a huge diff. I have the 1 PWM controller running my feeds.
    • Driving around town in summer, probably like 50°C tops. Went for a 2 hour drive before in summer, somewhere in the 60°C Mind you, I have 3x fuel pumps. 2x 460L 1x DW200
    • Good advice, I’ll try that.  and yeah i thought 5 degrees was a lot as well. The gates T291RB timing belt that was recommended for this engine was kinda tight when installing it and with both cams inline with the timing marks, the belt teeth wouldn’t line up with the gear. So I just turned the whole exhaust cam gear like half a tooth so the belt would go on and then adjusted the cam back inline with the timing mark, so some of that 5 degrees is from that. The actual cam has probably only changed about 2-3 degrees if that makes any sense lol also wouldn’t stuff like decking material from the block, head and different thickness of headgasket and the fact that it’s a rb30 bottom end affect the accuracy of the original timing marks?
