Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
  On 23/11/2011 at 11:11 PM, wilorichie said:
That's pretty cheap :O
I found most of the general tyre places around here hardly have 265's :( I had one tell me they can order them in but its $500 a wheel.... l o l
I'm really just after average tyres, but $210 for federal's ...
Well that's what I paid, the girl quoted me cost and she had to honor it :) hahaha
but shouldnt be much more than that.
Failing that I am pretty sure ERD are a Federal dealer.... not 100% but Dan does at least know some peoples.
Yeah don't listen to most places lol. Option 1 sell em for $220 I think fitted in those sizes. You don't want to be paying much more for them than that.
  On 24/11/2011 at 2:15 AM, hylian said:
Work is also shit at my end today.
We just had the annual fire evacuation, 20 floors of stairs is never a good idea.
  On 24/11/2011 at 2:20 AM, Smity42 said:
Use the lifts :thumbsup:
LOL Lifts are always a good idea when there is a fire... no one will be using them :) and if people catch you just say you were already in there.... .
On another note, I am so bored I am organising my US holiday already :( I am up to $4700ish without spending money and food.
Edited by EAT26
So we walked to the botanical gardens. Chillaxed there for a while and then went back to waterfront place. Now, 30+ floors of people, all trying to get into the lifts at the same time. Sigh.
Get back, new guy who's on more money than I am apparently can't distinguish the difference between a work order and a trouble ticket. Headfark.
Also, my non official mrs is in NY at the moment. Pretty cold I hear.
Edited by hylian
LOL yeah, when ever there was a fire alarm at Council I use to just go to the pub cause they would all be about 2-3pm I left at 4pm so most of the time by the time I got up to get my stuff it was like blehhhh home time...
Non-Official misses? in otherwords not FB Official ? :P
Pretty much the plan is.... for October next year(Assuming GTR doesn't need more love lol)
Fly to L.a. and fly back from NY
Around $1500ish
http://www.intrepidtravel.com/trips/SSOZC#overview
$2070.00
Fly from Seattle to Washington DC.
About $150.00 each J
http://www.onboarddctours.com/dc-it-all/
Then fly from DC to NY
About $165.00 each.
http://www.intrepidtravel.com/trips/SSAA-O#overview
$415.00
So far...
That’s $4700 without spending money or food money but covers MOST of the costs of rooms etc I would hope
Edited by EAT26
Battle to keep monitors has been won, although I wouldn't put it past them to just replace them tonight anyway...
Will be 'upgraded' to widescreen as soon as the warranty on them runs out though :(
What kind of monitors?
  On 24/11/2011 at 3:31 AM, Smity42 said:
Ahhh kk, Yeah We use Dell here but Council use to use HP. Much of a muchness.... Apple > Everything ;):P
If they are going to replace 'em make sure they get you a 16:10 monitor at least. mate of mine has a 27" one, and its not a bad amount of space at all.
That is actually the case here :P
Just been offered a position up in NT, 20k more a year on a 7 on 7 off roster, flights to cairns paid for. Interesting.
Naah the replacements are all 22" widescreen thingos. Not even full 1080P :down:
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
