Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
funkymonkey
TFIF indeed, I did not get the job I have been acting in for the best part of a year, need to get blind, This is what happens when the selection process is being run by other units and not your own.
What role was it? I heard a bunch of contractors applied for this Acc Payable role, and none of them got it. Even though they'd been doing the job for some 6+ months.
I also, applied for a job today. Me and someone else and the selection team are all recommending me.
I also just found out that In Flames, Lamb of God and The Black Dahlia Murder will be playing at Eatons Hill Hotel in Feb!
Edited by hylian
bummer dude :( sorry to hear that
I was a bit pissed when I first found out...but then I realised that in 10 months time I will be able to apply to 'progess' my role into that same payscale anyway so at worst I have only been set back 10 months. And in talking to my boss I dont think he is going to fill the vacancies in our team from that order of merit anyway as he doesnt like the order so he may be running his own process for our team soon.
6/64 now. I should have f*cking taped it, the game will be over before I get home tonight at this rate...
They really have no business in international cricket
Principal Environmental Officer in DERM
Rain delayed again... Bloody rain. At least it will save us a bit of embarrassment. 1/7 currently.
I dont think we will have much to be embaressed about in a few sessions time when we have an epic lead!
f**k the weather.
f**k Phil Hughes is a useless prick. Lucky we dropped Catto, he would never have been able to match P.H.'s amazing feats of getting out the same way three times in a row for f*ck all...
@Carl: Yes, suit up :thumbsup:
I've called and check if the Go Kart is available next Saturday and the reply was only at 1pm. Anyone keen or should we try next year?
I wont be able to do 1pm. Up to you guys though.
Smity,
Some dudes wearing white will stand around and chase a small red ball while the commentators discuss banalities like the number of seagulls that were on the field when Australia played England in 1988 and how that compares to today's game.
I actually like cricket but this test is a bit of a farce from both sides.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
