Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Dan [ERD] has posted this previously, and it's not the be all and end all of oil tests but it gives you a good guide:
http://www.animegame...Oil%20Tests.pdf
wowsers. very interesting test.
seems ill try something else next time, royal purple seems the go!
but only a few of the full synthetics seem to actually look different. the rest is all very much the same with a different pretty pattern. funny how some of the cheaper oils are much better than the exy ones of the same brand.
so acording to that if i were to buy penrite it would and could only be the fully Syn....which is funny cause i used all the expensive SIN oils in my box and diff......and they blow. it was a bit nicer for about a month then back to a sticky 1-2 change on cold winter mornings (only the first change or 2). and the noise and feel are back to exactly as they were. will be trying the Redline next time on those.
nice!! decided you needed more to fill your time??
anyone here have a windscreen squirter motor for an R33, mines dead. the rear one works fine so hope fully i can just find the motor for the front one >_<
We needed a motor for the ute so instead of just buying a motor and box we decided it was better to just grab a whole car. Should keep us fairly busy :thumbsup:
Morning Mangs
Morning Mangs,
Monday :(. But last week of work :).
Finished 24 hours of le mans last night, epic. Just nurburgring to go now...
that sounds like an interesting oil you running there smity. hows the oil pressure? im still vary wary of penrite.
I noticed low pressure earlier this week, but to be fair it is quite old and I did accidentally top it up with the oil I use for the XF before happy laps... so that probably didn't help. I changed the oil and filter that arvo (using the penrite SIN again) and it has been all good since then. No issues with pressure other than that.
http://www.animegame.com/cars/Oil%20Tests.pdf
I am guessing mine is the same as the full synthetic penrite in that, just marketed under the "SIN" branding. Seemed to do pretty good in the test.
I use SIN in the diff - no complaints. Also use SIN brake fluid and it is good too.
Redline LW shockproof for the gearbox, that stuff is magic. Although, Noel, Gervase, and ERD Dan all seem to have had some issues with it forcing its way out of the breather, this has not been a problem for me so far.
Mangs,
[snip]
That is all.
What a sh*tbox! :P
Yeah it's a heap of shit lol. But it has some gauges and a pretty steering wheel and a brand new loom apparently so should be good. :thumbsup:
Yeah same mang. Trying to achieve as little as possible this week. It's 8:30 and I havent left the office yet. Great success.
same. been sitting here doing emails.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
