Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I'm reverse parallel parking outside The Coffee Lounge in Toowong on Sherwood Road in the van, some old guy in a shit box Honda comes speeding round the corner and nearly crashes into me, then sits there on the horn for a while, then drives on the other side of the road against oncoming traffic to get past. I wish I could have beaten the dream boats head into his steering wheel so his face became one with the horn...
/rage
Sunday, not Saturday. For some reason I thought brekky out at lakeside was Sat.
This puts a spanner in the works. I am going to be extremely hung over.
Good old QR. couldn't organise a piss up in a brewery.
Wish I could attend. Chomping at the bit to get back behind the wheel. Now that I've sourced some second hand options for the front bar I'm being told end of next week at the latest.
yay for having a time for Happy laps.
Nay for the german club unfortunately.....having dinner with friends....i say
Soooo, it says im still watching topics etc.......but cant find the quick reference that used to be on the right side of the screen..... :(
oh..and why is it our profile pic now instead of the avatar? these are the pics that show on my phone, but the site used to have different ones?....im sure it will all become clear in the long run......
or we could all just rage out and have a big cry because we dont like change?? (happened alot with the last update... :P )
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
