Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
What happened to the job at Indooroopilly? Thought you were meant to be working on the renovations there.
Also, if you end up working on road projects I'm going to hold you personally responsible for every pothole I hit from now until eternity :P
We still have the job at Indro but looks like I'll be changing jobs. Got a job offer that is pretty much twice what I'm on now 14/5 roster with 2 days for flying.
Find any TIs?
+1
f**kin unlikely you'll ever be driving on these roads anyway
Easy enough to blame you any way
sweet news on the job offer!
so is that 14 on, 1 fly, 5 off, 1 fly?
Yeah that's pretty much how it goes. Director wants to have a meeting on Monday to discuss it but I'm pretty set on leaving. Will be putting in my resignation on Monday and then probably be starting out there in the 22nd of May or something like that. Need to hang around to get completion stuff sorted on this project.
Relevant
Mmmmmmm...
no parts to work on the leopard and too raining to work on the skyline
lazy sunday it is
I've got 2500 words to write and so far all I've done is watched Top Gear and Jimmy Carr...
After fitting the exhaust my coilpack misfire (or so i assume) seems worse. (although it only happened on track...not after i left lakeside)
there are plenty of threads on coilpacks etc on the forums, but i thought id come ask you guys personally. ive done the tape and silicone thing about 40k ago, and has lasted well since then. but now its time to replace. so my question is......(drum roll)
are yellow jackets, or the red coilpacks any good? or should i just go for the splitfires for a whole lot more folding cash? i wanna stay with standard location and fitment for the sake of keeping it neat underneath with minimal hassle (yeah i'm a bit slack at times)
I'm running yellow jackets, no complaints so far!
Straight fit and they are working like a charm.
Might be worth checking your voltage at the coil packs though, as my missing was caused by voltage drop in the wiring, fixed by a relay.
In other news, morning mangs, f*ck mondays. Did manage to get some work done on the leopard (re-fitted coil packs and replaced fuel lines), and the sun came out so I could at least swap the tyres back on the wedge.
Now definitely need leopard parts for more progress :(
cheers man, i heard you saying something like that the other day about the voltage drop. i can fix pretty much anything mechanical...but am entirely useless when it comes to electrics. So i really wouldnt know where to start. could prob find the right wires, but as for testing...thats where i get lost.
yellow jackets might be the go, my old coils have done 40k with the tape job done and that lasted a while (might even have another look)
in air I am told :)
wet morning is wet. bludging net access off mcd wifi.
martin, should have a number for you today. hoping to get the 31 on a hoist today at some point as well.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
