Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Morning Mangs,
Monday :(
On the bright side though... 2 day week! :D
how??
I have tommorrow and wed off (sort of) would love to know how you score a 5 days off..
heaps winning. Strayan as f*ck.
nah. What you needed to do was go "well now that you've given me those 2 days off for a 5 day weekend i'm hardly likely to turn up on monday and tuesday, so why don't you give me those off too"
Unfortunately, I've got a workshop to go to next week :(
T minus 4 hours and counting
similar setup here. last day of the week. tons of work....
is there noticeable improvements in ride with hubcentric rings? getting some longer wheel studs from gktech and wondering whether I should get some to go with my wheels and spacers?
you should, but 10mm slip ons are thicker than the hubcentric rings so they probably won't do anything.
What you really should do is get custom spacers made that match the hub center bore on the inside and the wheel center bore on the outside, then no need for rings!
what you should do is get the right offset wheels. Failing that you can buy hubcentric spacers.
it's not the offset of the wheel that's the issue, it's the fact that one sits flush with the guard where the other noticeably sits about 10mm in, and it's giving me the shits.
will google hubcentric spacers
but in general, are hub centric rings recommended on aftermarket wheels?
Heard that misso, It is very common with skylines. I dont think I have seen them the same yet.
ARC are a bunch of smart cookies. Their sidemounts bolt in just fine... its just when you go put the wheel arch lining on that stuff starts to get distorted. But still, its bolt on :P
Nothing to serious though, it can easily be secured by the bolts/attachers that do fit, and zip ties to do the rest, so its not going anywhere, but just a bit floppy.
There isn't. Maybe the kit came with a new lining when new? It only needs to go back 5-10mm. Like i said, the standard one fits over it with a little bending meaning osme of the other mounting poitns are out.
and don't get me wrong, i'm stoked with the cooler itself.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
