Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Are they multi stud John?
I assume not, don't think I've seen any multi stud advans. Would be keen to take them for the ute if they're 4 stud.
oh and Morning Mangs,
So the exhaust has fallen off my car again, at the cat. Needs moar locktite lol. Also I'm getting some terrible squealing noises, sounds like they're coming from the pulleys at the front of the motor...maybe bearings gone in them or something? Anyone know how difficult these are to change?
could be belts, you can always try some baby powder :P
we are simply friendly vultures your yet to meet
Colon, 5 stud.
Misso, you're PM was in before these other vultures that I don't know, so they're yours. Come and get them :)
Colon, 5 stud.
Lol. Pm me your address, number and an alcoholic six pack of choice and we will work out a time.
Please note, if no alcoholic beverage is stipulated it will default to bourbon, and I will possibly drink half of them on my way out there
Colin use different nuts to hold the exhaust together. If you drive it more often those noises don't occur, i stopped driving mine for a while and the damn battery died :whistling:
maccas tonight?
gonna try and sort out a few northerners, and might come visit. ralf has his car back from Dan. and im sure he's keen for a nice drive
Gah stupid f**king cars. Went to fix my exhaust yesterday after its been dangling loose for a day or so and the f**king exhaust is bent. Bought another catback from option 1. Atleast now I've only got to fix the starter, noisy pulleys/belts and the turbos. And clean it. And repaint the front bar. And replace the drivers side mirror...f**king cars.
maccas tonight?
yeah i'm keen. old girl is working so Maccas for me.
I am having a German Club meet in about 27 minutes. Reduced menu at the moment as the kitchen is being overhauled but the pork pie is epic and only $12
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
