Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
they'll get a sponsor no problem, the team is a good team always up the pointy end so good advertising for the right price.
When Betta Electrical went belly up it only took a couple weeks to get vodafailure onboard, my guess is they already knew so won't be short sponsorship next season
so where would you guys suggest buying coilpacks from?
best ive found so far for a series 2 is $440 del for yellow jackets.
and splitfires $575 del.
for the extra 135...should i just go splitfires?
well nothing that ive heard...just splitfires are alot more tried and tested and proven, i guess only because they've been around longer.
having said that...i do have a mixed opinion of splitfire anyways. my bug has splitfire plugs (about8 yrs old now...and the only performance thing available at the time), which work great. but my splitfire tacho...also in the bug.....leaves alot to be desired (VDO should have been my choice here)
lol.
for peace of mind?.... :domokun:
I have ordered the yellow jackets from performance-wise. $410 express posted! should have them in for next weekends happyness of lappyness.
just spent 2 hours fitting in this "reco'd" brake master cylinder, bled it up only to find when i tested it the thing still leaks out the rear seal
unless you have no other choice....never reco a brake cylinder. (is what ive learnt over time) and the kits are generally almost as much as the whole new part. :)
yellow jackets arrived today. epic delivery time from Performance-Wise!!
mmm poast.
day after origin...i wasnt heading out tonight.
on a related topic, coil packs are in in record time! 1hour between turning the car off when i got home, to firing it up for a test run. :woot: (engines are quite warm for a while after turning the car off...)
they work great, cant wait to hit lakeside on Sunday
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
