Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Dear Dave,
seen it mate, got photos of it sliding to, but i'll raise by not 1 but 2
^^^ this is my inspiration to my next 32
and as for that fuel pump i got a $10 solution for ya in my pile.
haha yeh I saw his drift pics.
I'd buy it, even just as a tester, but I cannot get out to get it. My car is garage bound, end of my street and it dies. I can get to toowong shopping centre by city cat, about as far as I can go
i could bring the pump somewhere and meet you? try get as far as you can with ur 32 and we'll replace the pump on the side of the road LOL.
:thanks:
Too broken haha. Let me know when your finish work and i'll see if there is a city cat running to toowong
Hey Colin,
You know how you hate me and stuff? Well... I just went to McDonalds... and wound up having the counter girl for dessert :worship::(
You picked up at Maccas.....wow..
Maccas...
If it was Hungry Jacks, then hi 5 time, but Maccas. :worship:
+1
The chick on the drive through at HJs was a stunner. No desert for me though :yes:
Thats because you drive a skyline, if you had a commy with fully sick chrome wheels and 15 subwoofers then she would have been out the window like a flash.
*sigh*
T88 install update:
- Fuel filter looked fine
- There is some grit in the tank, not enough to warrant pulling the tank out
- Fuel pump is the original item still had all factory seals
The pump filter that sits in the thank is brown and had gritty alloy looking rubbish on it (I assume from the alloy nozzles at fuel stations. I'm hoping it's just a case of a 20 year old pump :yes:
Now taking bets I might have f**ked something
- Standard one way valve after the fuel filter, before the injectors perhaps?
Dave:
As far as I know my car still has the AUTO ecu, do you have one of your manual ones you can check the numbers on?? I have no idea what numbers you need (if you know let me know and i'll get my ones).
If i do indeed still have the auto one.. I'll take one of those manual puppies too
looks like you found me... good start.
friends suggestions for everyone else sent to you.
I don't have any bloody pics! Nice little 18 year old emo bitch. Fun times.
No pics, it didnt happen
yeah i found most of you from the BR page :yes:
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
