Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I skid on public roads. Hahah. Sorry, am I wrecking the image clean up your trying to do?
lol yeeh i figured it wouldnt be clean image for long
Rb20's can die
*cant
*cant
Well sometimes can't. Sometimes can.
I like to think I have enough skill, too kill them
Fark your image.
Wow I just finished reading that rotary thread. A good read, there's some proper idiots in there, as well as some truly informed people with a lot of one-sided opinions.
You sticking a POD on those turbos or anything dude? Or do you just leave them open?
Hahah nah man there will be a 4" intake pipe wit pod on the turbs when its finished.
that thing is going to sound f**king mean
yeah after about the 5th page you don't need to read anymore because the next 10 pages are the same opinions reworded over and over lol.
your using a jim berry clutch irght or plan on using one??
check this thread
My name is Danski and im going to cup everyone for 25mins this thursday! give me some duuuurrrrty nutzors!
IMHO - Hit up PCE Performance for clutch upgrades with well known and respected brands..!
Woooo u knw it :P
check this thread
Yeah ive got a jim berry clutch and no I dont need to replace it because I bought it with 300rwkw in mind
on a seirous note - dan have you got a call from efi today? are they able to start tuning her yet?
Yeah they said it was booked in for tune this morning :D
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
