Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
52mm alloy dual core rad has arrived with new piping!
cbf putting it in.. might way for it to either shit itself or new engine transplant..
looks huge.. i dont think there will be much clearance or fk all actually for clutch fan and shroud
So you're the one trying to get rid of the radiator...
I'm looking at getting the 40mm one from justjap.
BAHAHAHAHAHAHAHAHAHA just went out to test out the Bee*R flatshifting mode.
Got literally 10m from my driveway and saw a cop car in the driveway of the golf course
so, quickly turned it off, did a lap of the block, and went back in to the garage. Sirens on, cop comes up for RBT.
All good, blew 0. She was actually quite nice, had a bit of a chat. To be fair I would have looked really suspicious :). Might stay out of trouble for the rest of the night...
f**k you and your good luck martin. if that was me i'd be arrested for sure.
Thats because you would have:
Dan says:
should have just shut [the garage] and run out the back door
i think i would be the heaviest out of the thursday crew, with a lazy 115kg
somebody is welcome to prove me wrong
encouraged even
i heard dave was writing you off, saying he weighs more, you aint shit and packs a meaner punch...
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
