Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
is the 32 running sweet now?
Running peeeeeeeeeerfect. I want to keep it, but the honest reason is work has said no way. There is some movement in $6850, Im sure as hell not wasting my time running around for a RWC at that price though.
Could be? Im sure he'll chime in.
Basicaly just need it gone, great little runner after selling a kidney to bring it up to spec too.
How much u get for your kidney?
Enough to bring the maintenance up to spec on my R32 and go a little OCD on replacing things that didn’t need to be done right now, but wanted to so some little in-grade didn’t whine 6 months after buying my car.
Enough to bring the maintenance up to spec on my R32 and go a little OCD on replacing things that didn't need to be done right now, but wanted to so some little in-grand didn't whine 6 months after buying my car.
Hahaha
told you josh keep it and then turn it in to a track car.
Work > Cars
Too busy to muck around with playing "track racing".
Good road car doesn't make a good track car and a good track car doesn't make a good road car. Need a good road car for work, so.. Life be like :laugh:
obviously..
but i said track car as in slowly over time.
a) where would I keep it
b) When would I use it (working 6 days a week is a good week for example..)
etc
In an ideal world, your plan would be great. I live in an unside down world.
A,) Daddy's house?
B.) Over time when it is acutally completed then you can ask that again
I am the same as you and i still manage it
a) He already has two cars. No where to leave it.
b) why hold onto something long term, when I can turn that 6k - 7k into 14k over the time it would take me to finish it, not to mention ever use it.
Why on earth would you IMPORT a friggin skyline when they are cheaper to buy here. Thats a fact.
R33's are a buyers market.. You can get them with coolers and exhausts for 5 - 6k with rego
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
