Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
why dont we just convert your gtr into a track only one..
we can gut it out, and put in a rwd switch - its simple rlly - and cheaper than spending 10k on a sr
:P:D
sr's are for people with vagina's
got in to work late today yay. hose clamp on my twin turbo pipe slipped off. wasnt even a proper hoseclamp f**kin stupid whoever put it there but anyway. Its all good now just took me an hour to find a place in Jimboomba that sells clamps in the right size. Ended up at some pump repair place lol. One more thing to add to my glove box repair kit.
freeway driving in 3rd?
you gracing us with your emo'ish ways tonight nismo? astro is a quitter..
cold!
WHEN NO ONE CAME TO SEE YOU AT B&R - I DID!
yeh motherf**ker
WHEN NO ONE WAS GOING TO HELP YOU AND SHAN STEAL RIMS - I WAS THERE
yeh!
you dog
full of it.. Coffee square, Little hong kong are rip off and gives you food poising.
Little singapore*which owns little hong kong* is a rip off has hk/malay chefs not sg chefs.
malaya corner is a rip.. order tom yum chicken wings came out nuked over cooked
Thai orchid - A bunch of chinese owns it great authenticity
the only place i eat at is the viet place..
if you want asian food you just go up the road where the roundabout with the BP.. the asian food place there actually makes great food..
I'm aware of these. But they do serve pretty decent food there. You cant really expect much in Brissy... food wise. Anyway I like the Taiwanese places more nowadays. The fried chicken fillet is awesome.
wow that sucks what type of engine is that again beelzebub??? an RB perhaps?
Yep the insane power of the RB vibrated the hose clamp loose. Its a shame but an easy fix. :D
Was like 10mins from home, engine all nice and warm. give it a bootful coming out of a t intersection and no boost.
Only if we can cry while listening to FFTL
Are you gunna cuddle aswell?
yeh!
You was about to sh*T yo pants.. was like cmon guys.. i dont like it being here.. we was the epic trio of multi nations
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
