Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
hate you guys...seriously. On a happy note. I didn't realise AUD has been getting stronger against the yen again. Bring on 110yen to the dollar! Hopefully by the time I can afford to start buying some gear for the gtr it will have recovered fully ;)
some people are predicting we could hit over 100us before Christmas as we are one of the better placed ecconomies in the world so surely we would be over 100yen at that stage too, they are probably pretty hopeful but still our dollar is going to get really strong soon by all accounts
its strong agains the US dollar atm, mainly because the US dollar is so sh*t
currently .92 US or something and about 84 yen. So when (if) it hits 1US, It'll still be under 100 yen.
They predicted around it would reach parity with the US dollar around this time last year... then look what happened ;)
Edited by Smity42
omg servo food is making my guts so saw ;)
yes i have all ranges of sparco shiet in stock..
after a fancy pair of gloves to be like tsuchiiya?
lol no... more like a shift knob and shift boot.
why do you always get poisoned by servos?
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
