Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Re: Bob Jane - Valley - Rant
Bunch of ignorant f**ks. I work in New Farm so thought, why not I'll pop down and see what they can do. Walk in asking about semis, clown can’t get them, rings around and quotes way above everyone else (fair enough, guess he thought he could pick up a few bucks).. THEN!! Try's to tell me you cannot fit any 225 tire on 10.5+ inches, I kindly show him my car out the front with 10.5+ with 225's..
Tried to up sell some all rounder POS tire as a sports tire for $480each, with the argument of "some guy with a commodore swears by them". Told me I'll have to buy tubes off him so he can "expand" the tire on the rim and all sorts of voodoo magic tricks.
Apparently he used to "tek-screw" drag slicks onto his "drag cars" and he is old school and knows a thing or two.
f**k you Bob Jane Fortitude Valley and to the guy who has the POS white S13 that works there your car is shit
@ nismoh - unfortunately ive heard bad shit from those guys too (i used to work at dominos new farm, and when i was looking for tyres i was told never go to them)
ugh f**king mustangs
im so pissed katie's 32 got pinched
We should jerk on there door
lol i think emo hair styles make u gay..
luckily i dont have one.. :P
i just did a clutch change a on burnt out R33.. the smell was so bad even the interior smelt like it.. ffuu :P
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
