Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Side note : Did i tell you's that if i can get enough donations I will be growing a hitler still moustache for movember... but I might call it a chaplin... not sure the jury is out on that one.
Hmmm, I think a chaplin moustache is a little bigger than a hitler one. I'm willing to donate if you do an actual hitler one, and rock it to a meet. You can call it whatever you like, but you'd damn well better look like hitler :(
Done hitlering it up. . I'll get the donation forms etc ;)
I was rebuilding engines and gearboxes in my first year, the good part of being an apprentice in a small workshop. Yep clutches is actually taught in the second year tafe module. So yer they do teach that in as a 2nd year apprentice.
From my veiw, exedy is ok for an off the shelf application, i got one in mine thats lasted 3 years so far, i wasn't too happy with its clamping force so i had that beefed up by jim berry, its got a really nice feel to it now, not a weak stock feel. But i have driven smity42's clutch that jim made and its a great clutch doesn't slip and feels really nice on the pickup.
Also a jim berry clutch will last about 2 times longer in a ferrari than the standard one will.
My next clutch will probably be an OS or something like that.
Exedy do make a nice lightweight flywheel though
Yep all tax deductible. Signed up on the website and everything. Should have put the mo to a poll and seen which one would have been the coolest. We could change that ? Or still keen on the "hitler" ?
There was a pole ? Man why wasn't I informed ? Sheesh..
Sorry haha next time i will be sure to inform you :(
Excellent. Always like a good pole...action...
So wrong ;);)
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
