Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
your better off with this
found it on astro's comp!
Nice edit...but not quick enough
Seriously though, where do you get a picture like that Taz? You certainly pulled it up pretty quickly
Thought this would be cool on my 33. Just trying to mount it up in a way that my EPIRB wont get in the way.
Standard equipment on all bogan spec vehicles. :(
Shouldn't you mount the EPIRB on the bow?
can I get in on the emo boy tug-o-war?
No real tug feast, Dan is offering advice. This is a forum after all. Not sure if your post was meant to be directed at me or not??
I personally destroyed the brand of clutch in question; I was ripped off and taken on a wild run by the company. I will continue to voice my hate for as long as I can.
I will keep on telling people to steer clear of said brand. There is a fine-line with what I post, I can get away with what I say Re: this clutch as it did in fact happened. I figure, I am offering my 2cents on said brand.
Having driven on an array of singles, OS twins, NPC rebuilt twins and a few Japanese triple plates and a triple plate rebuilt by NPC to twin plate spec.
A 3puck is one of the worst clutches I have ever driven on, as already stated. It has limited streetabilty, it’s costly on driveline as well as hard on driveline.
Tas did the right thing and sold Tristan what he wanted, Tristan wanted a “drift” clutch – However, his application could have been better look after with better options – Again, he wanted a drift clutch and that’s what he got.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
