Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Have a yarn with zenon Josh, Thats about where he's at with some carefully thought out spenshun mods and he has a ball in that flat capper of his.
Yeh might hit him up. My teins gotta go! no question there. Dont even think they are worth trying to save with less silly spring rates in them
T51Z on a stock rb20, and then change the timing belt.
and then fit a new intercooler.
then some more parts.
then wait a couple weeks
RB24 is a waste of time.
Plenty can be done with the RB20. Need to spend a bit on cylinder head work though if you want the numbers and torque.
Leave the bottom end for now, take off the head and put on a pre-ported one with bigger valves etc. Go Pon cams, Angry German with surge tank injectors and a NISTUNE or I have an ECU in my 20 which has already been chipped and I won't be needing it. Already set up for 550's and a Z32AFM
I can't use AFM with the new setup as there is nothing big enough for 1rwkhp
So all you'd need would be injectors, fuel system, JJ intercooler and a couple of other bits and pieces. Could easily get 220rwkw on that turbo.
Then when you can afford more of an upgrade (or even want one) do the cylinder head and go bigger turbo/cams. You can make 235rwkw on the stock cams with stock/untouched head.
You can also do 205-210 rwkw on stock injectors and AFM too but I would be careful running them at those levels.
Is it worth toying with cam gears? Or not worth it unless I went to a full ECU?
Worth my time buying a 6boost manifold for the current turbo? (I have no views of going high mount/ex gates).
The key is, response, keeping it alive and staying consistent
No, stay factory manifold but maybe heat coat inside and out.
easy to keep it alive but revs will have to be cut short at 8k until you can afford/want bottom end work. And I'm not talking about beat kind of bottom end work.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
