Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
that seems like a lot of effort to go to...
sounds like you're just out of download and want me to hook you up!
Nah man.. I'm doing the kids of the world a service. I'm trying to get rid of all the pron on the internets. If I d/l it all no one else will have it. Just wanted to give you a heads up so you could get some before i got it all .
ok maybe no martin - that dog is running too much camber :P
HEY! I have nice camber now
Yep got crappy tyres.
Well there's ya problem :P. Naah but as the other guys have said, too many variables. Sounds like you MAY benefit from more front camber, but could be plenty of other things as well.
R33 stocko rims for sale! without tyres! pm!
How much?
heyy... theres a remote on the desk, and a tv mounted on that pillar.
Anything decent on tonight?
Hi Geoff! ;)
I now know why dad was bugging me to come pick up the ute - my birthday present is in the tray :). Pics as soon as I get it out (or find some on the internet).
EDIT:
:D:thumbsup::cheers::banana:
Edited by Smity42
This is all of brisbane water mains.
end lesson
Nope its all carp.
Do i get square eyes? Sometimes :cheers:
1 hr to go til beer o'clock
:thumbsup:;)
I'm actually going to ask a serious question.... I think i'm ill
I recently got coil overs and underbody kit and etc.. Now I've got 17" 235 ( standard size tyres ) after I got the coilovers etc done it scrubs on the guards and understeers like a bsatard and spins the rears in the wet. I spoke to a fella from a tyre place and he said that it would be because the tyres are like this | | and not like this / \. Is that the case here ? Or am i missing something? If the tyres are like | | less traction and understeer ? / \ no understeer and heaps of traction ?
It's possible the camber is wrong but I think you'll find that the spring rates are too high.
What brand coilover?
XA extreme's
Ahh Pedders.
Any idea on the spring rates?
If not, can you tell me the coil outer diameter, number of coils including the flat ground ones, thickness of wire and total height?
Ahh Pedders.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
