Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
funkymonkey
What's the point of going a dirty 30 if you aren't going to do it properly?
Cast pistons and 12psi on a 35 will net you around 300-320rwhp. Nothing that can't be done on a stock 25 with less mucking around.
Don't worry, I know what Dan's 'plans' are like. I've got $5 on this 25/30 never even gets built :D
We do have rather similar taste don't we?
Thats because you are a man of fine taste
Everyone wants to be in Josh :)
You know it ;)
tristan what offsets you looking for??!?!?
size:
17 x 8 9/114.3 ET34
17 x 9 9/114.3 ET35
17 x 9.5 9/114.3 ET18
18 x 8.5 9/114.3 ET34
18 x 9.5 9/114.3 ET35
18 x 9.5 9/114.3 ET18
ugh they are all shit (except for 9.5s) - i wanted 17*9 +15ish :)
gaaaayy
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
    • Hoping they release an R34 getrag pull type.
    • You need the bottom spacers, to make it a 3/4 height injector. https://www.efihardware.com/products/3040/injector-adapter-lower-for-extended-nose-injectors   And you'll need to buy the right injector bosses, these "might" fit. You'll need to measure it up. https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
