Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Im prob just reading this wrong but this is what I found.
The GTS-t Type M included larger five-stud 16 inch wheels, four piston front callipers and twin piston rears. ABS was optional (except for the GT-R), viscous LSD was standard on all turbo models and optional on all but the GXi. Nissan also produced 100 Australian models of the R32. These were the only non-Japan only Skylines ever produced. There was also a 4WD version of the GTS-t Type M, called the GTS-4.
Please explain :)
Just so you all know.. HAVE YOU EVER SEEN A GENUINE TURBO! R32 that wasn't a Type-M.. No, you havent. They all have 4 pot fronts and 5 stud hubs. It's just a marketing hype.. All friggen turbo R32's are Type-M's with different trim levels, just like options and trim levels on any other car.
Please explain :)
Learn about full stops. :D
The 100 Australian models were GT-Rs. They weren't produced in Australia though (AFAIK), they were produced in Japan but locally delivered by Australian nissan dealers (To be fair this information is not described in that quote). The bit aboute the GTS-4 is the next sentance and is unrelated to the previous.
It is definitely poorly worded. Just goes to show you can't always trust wikipedia
Ah k cool bananas :D
Yeah I obviously dont know much about cars thats why I was asking if that stuff was right :down:
ROLL CALL!
my brothers formal is on tuesday night - and as he was discussing a few weeks ago he was hoping if we could all do a drive thru for him
he wants to get there at 6 and its being held at the hilton in the city
hopefully some of you guys can help him out :)
ROLL CALL!
WWWWWWWWWWAAAAAAAAAAAAAZZZZZZZZZZZZZZZUUUUUUUUUUUUUPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!!!!!!!
so thats a yes?
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
