Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
thats all jap
ahhhhhhh! I dunno... all asians look the same :D
Yep doing the day shift.
Its awesome. :sick:
Any work going there?
found out why skins loves to go drinking in toowoomba
LOL no way dude. Toowoomba chicks are loose and easy, and suffer from hallway hotdog syndrome. Much like a lovely lady we all know ;)
I like the way you think...
I'll let you know how they fired me on tuesday :)
See if you can get classes as an "unwelcome distraction" like I did!!
copgyf*cker
:D
Play nice.
I have a Cert III in water operations and 5 years experience as a water treatment plant operator. I also have 3 years experience working on a plumbing crew. For this job you wouldn't need a Water ticket but you would need to have a bit of experience working with pipes, prv's, valves etc. What they look for is someone who has experience in moving bulk water.
Or a mate who works on the inside who will give you all the answers.....
at a price
:sick:
MacGyver is cooler than any of you will ever be :):cool:
Martin - I bought this Kenwood unit :P:bunny:
Still looking for a good amp though. The car already has some MTX Audio speakers in it :banana:
Should I get a wiring kit? Or just buy some 0, 2 and 4 gauge wire?
hello hello,
just got home
it was f**king hot today - got a heap of work done on the 32 and 180 today however :banana:
It was hot!! Glad I was at the shops and or in an airconditioned house and car all day!!
What were you doing on the tractor? Smoke stack need polishing?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
