Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
it's ok if you can't
All good breh, we'll get solder monkey (dan) to do all the hard work)
Didn't even wish me a happy birthday
It's still monday in colin's homeland: HAPPY BIRTHDAY!
just enter with more speed
That's what she said
tomorrow hopefully = registered and driving
w00t
this vid is for martin!
Damnit, will have to watch it at home
:D
+1, I guess
Martin and I consider it gospel :)
Lets start the day off with a video of Redbum in his 32 giving the boat boiz a drifting lesson.
http://www.youtube.com/watch?v=5Ty3LSY4N6g...feature=related
;):huh: :huh: :huh: :huh: :huh: :huh:
I'm not sure which question to ask first...
So GTR is for sale. 94 model really clean you guys know what its like. $24k. Price is negotiable. Need it gone pretty quick.
License has been suspended for 6 months plus possibly another 3-6 after that. I might be able to keep the car but I have to move out down the gold coast. I probably can't afford to move out and pay off the car.
Well chances are with the market the way it is atm it wont sell in that time frame Col so you'll probably get to keep it. ;)
Yeah its a worry. Found a place in surfers that's only $180pw and I spend close to that in fuel every week so I might be able to do it. Would be awesome if I can keep it lol.
I know. :huh:
Edit: What happened?
Overtaking a semi and 4 other cars going up the hill through Canungra. I was in the overtaking lane but as I got to the top the highway patrol car came over the crest and got me. ;) 121km/h in a 70 zone. $933 fine and 8 points.
Overtaking a semi and 4 other cars going up the hill through Canungra. I was in the overtaking lane but as I got to the top the highway patrol car came over the crest and got me. :huh: 121km/h in a 70 zone. $933 fine and 8 points.
holy shit ;)
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
