Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Isola you putting a remote start alarm system on your car ? If so, do you know where the relay is so that the car doesn't start in gear ?
*end serious note back to reality*
oh look a duck.
It's the reverse switch that is faulty apparently... telling me the gearbox has to be dropped to replace it (bs)
Unless theres something retarded about GT-R boxes (possible), that is complete BS. It's easy to replace. See if you can find a replacement switch and we'll do it when we do the AWD fluid while the car is up on stands.
The brake light problem seems to be intermittent. Sometimes all four light up and the spoiler, sometimes the two centers lights up plus the spoiler, and sometimes just the two centers on their own.
Intermittant faults are always fun. Might have to take it to a more competant auto elec for that one :(
The alarm doesn't go off when the boot/bonnet/or doors are opened (when armed)
This should be pretty easy to fix, assuming he has installed the bonnet switch. Do you know if it immobilises?
- and the turbo timer doesn't work one out of every ten times the car is turned off (usually when I really WANT it to turn on too).
I'd say this isn't a wiring fault, and might be something you just have to live with. The way turbo timers work, it detects the voltage drop to 0V on the IGN line, then picks it back up to 12V, HOPEFULLY before the engine stops running. Once every now and again (particurly with air con on) my engine slows down too much and fails to stay running when the turbo timer kicks in. You can see it has kicked in on the display but, and it keeps all the ignition lights on and sh*t, the engine just stalls. I imagine that a built in turbo timer in an alarm possibly has a slower switchover, making it more likely for the car to stall in this time. Do all your ignition lights and stuff come on? Does your fan keep running?
and yeah, we'll have to investigate further with the head unit, and see if we can work out what's what.
Yep, sounds like fun :D I hate car audio :)
First thing to try will be cutting that handbrake switch wire.
Make sure to get me to look at it BEFORE i start drinking :)
and get those 6x9s mounted before you come round :D
oh, and on the way home the steering seemed to lose power. so that's probably the pump. GRRRRR!
Could just be low on fluid/old fluid
His isn't remote start, but such a relay would not be part of a manual car (they can start in gear) so it would have to be added when you install the alarm. Thus, it could be anywhere. Why do you ask, 2 dogs?
2 dogs ? Where ?
My relay seems to have died as I have a remote start on my car :D. Just wondered if it might be in a specific place.
Just like the gingers
We will rule the world one day.
LOL! No death is horrible enough for them
@Isola: Get your car back yet buddy?
:D
Going to go and pick it up shortly.
Really wish the idiots had have called me BEFORE they did any work though. Charging me $385 in labour because it took so long to try and track down a new unit for the fan... which they couldn't find, and wound up getting some holden unit, and that's another $80. If they had have just ASKED me, I would have said 'don't worry about it' bought one from the classifieds or wherever, and plugged it in myself. The fan wasn't even that much of an issue ffs.
Then they tell me a mechanic needs to do the reverse light. That my brake lights work fine (two witnesses say otherwise, as well as me braking outside a window at home every day) and that they've done nothing with the head unit or the alarm.
Not impressed. at all. Really pissed off would probably be a more appropriate description.
So don't anybody ever bother using Chermside Auto Electrical in Boothy Street at Kedron :)
Sounds like a piss poor effort. I wouldn't be giving them any money for that shit. You pay for them to work on the car not chase around finding parts. Complete and utter bullshit.
Damn, thats Terrible!
What do they reckon is wrong with the reverse lights? I can't see any reason a mechanic would have to look at it, its ALL wiring except for the reverse switch, which is a switch on the side of the gearbox that takes 2 minutes to replace. Sounds like they just CBF.
What is wrong with the brake lights exactly?
As for the alarm, I'd be figuring out exactly what it does and doesn't do, and get whoever installed it for you to fix it for free.
Head unit... yeah, I guess we'll have to look at that further
+1
Yea... Thats bs. I'm totally against people doing something without letting the owner know about it and then charging them for it. Its like "hey, your motor's f**ked and we swapped it with another 1 we have. That'll be 5 grand please." BS!
+1
The alarm doesn't go off when the boot/bonnet/or doors are opened (when armed) - and the turbo timer doesn't work one out of every ten times the car is turned off (usually when I really WANT it to turn on too).
Need to find out if all those features have actually been wired up. I know when Dad and I installed the alarm n immobiliser on Terri's old car all we hooked up was the immobiliser and alarm for when the doors are opened. Didn't bother with the boot or bonnet. Could be the case here.
You don't usually make assumptions....
You know what happens when you make an assumption? You make an ass out of u and umption.
Yep, sounds like fun :) I hate car audio :D
Make sure to get me to look at it BEFORE i start drinking :(
and get those 6x9s mounted before you come round :P
Intermittent fault is probably dodgey wiring somewhere. I'd start at the back rip the lights off and have a look around in there. If there is any dodgey shit cut it out and solder in some new stuff. You will end up paying through the ass for an auto elec to find shit like that because they know they can slack off n just blame it on the fact that the problem could be anywhere.
+1 on check/change powersteering fluid.
Got rejected on that unit that I applied for. Epic gayness they didn't even bother calling my references. Going to have a look at another one at 3 today and another at 4 tomorrow. Hopefully I find something soon. I might have to start looking at share houses down here which I don't really want :S
Crash at Dan's place! You can even drive his 34 when he's not around. Hahaha
@ john - man thats bs, did these guys fit up the alarm too? id be asking questions and asking for the alarm to be fitted CORRECTLY
as for the reverse lights and audio - no idea man, but i do know that martin loves drinking :) hahahah hint hint
I didn't even know you'd met Donna :)
Thats what i thought! lmao lmao
If you like married women with some extra cushion ..... :)
Hey Collin, i will join your ginger ninja army! :D
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
