Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I got a little bit drunk :)
Pulled a cam cover off, can't see any shims in there so it may not be a NEO head, which would mean I have been ripped off :(
Didnt see anything obviously wrong, and then spotted the stainless exhaust manifold was snapped almost in half. That could account for the funny noise, lack of power and boost, but not the low compression. But I don't have a lot of faith in my compression guage so yeah...
So the plan is to put it back together with a factory manifold and see how it goes. If its still f**ked, I'll take it somewhere for a compression test and leakdown test to work out whats wrong. But hopefully it wont come to that.
Need a new exh gasket and some other misc stuff though, but will hopefully be going back together next weekend. Oh, does anyway know where I can get the right sized copper washers for the banjo bolts? Super cheap/rapeco etc only have imperial ones.
Gonna be spitting chips if this head isn't a NEO one but.
i too will be spitting chips!
that is fcuking shit martin!
called up just cars today - cant get my quotes inspected til tuesday next week..
so no car for 2-3 weeks im guessing :|
seems the pushie is going to be used and abused lol
I'd lend you my backup, but I am using it ATM :P
Looks like it is definitely not a NEO head :). http://www.skylinesaustralia.com/forums/Ea...ad-t269422.html
Wrong number on the side of the head, wrong coil pack mounts. Shoulda researched this s**t more before buying it I suppose.
On the bright side, hopefully it will be all good when back together with factory exhaust manifold now. But the low compression is still a bit of a worry - hopefully its my guage.
Looks like it is definitely not a NEO head :D . http://www.skylinesaustralia.com/forums/Ea...ad-t269422.html
yeeh thats gay dude - hopefully it is just the guage and can be sorted out easily
*fingers crossed
I believe this SR is running a pretty compression all around :D hows yours doing!?
oh shiet :D:P
Too bad the shit bolted to the SR failed more than Johnny McFail at Fail Highschool in Failsville.
I made it out of the spit alive yesterday! I dont think I'll wanna go there again... that place its like a 1 way ticket to defects.
Anyway, anyone knows if the TE37 comes with dish? I saw 1 yesterday thats 19" x 10.5" +22 with massive dish... never seen it before (particularly for funky).
Any farewell car wash for monkey these few days before he gets on the van?
Edited by Brandon
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
