Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
It comes with a free bit of paper with "RB25" written on it :down:
Why are you selling your Bee*r?
On a side note, car is going to city suspension centre tomorrow for more low, camber adjustment and wheel alligment
new tyres from bosman tyres coming on saturday.
money money...
hahaha fair enough
coming out on thursday to show us the new epic low?
yeh, should be out there for my usual gym followed by energy drinks and bnr action
Because the last time I was there it looks like one way ticket to defect. I dont mind sitting in colins car and park at mirage or something though. :down:
What about a set of R33 rims? Throw them in?
I've seen your stuff for sale just sit here forever. You should accept it.
stab much? come play with the big boys one day and learn how to negotiate.
Isn't the exhaust the only thing on your car that's a bit naughty?
I don't haggle. People can advertise their stuff for what they want, and best of luck to them selling it at that price. If I want it for that price, I'll buy it. If it's not at a price I like, I'll go elsewhere. Haggling is just an insult.
So you "big boys" can "negotiate" all you want. I'll keep my manners and my respect for other people's wishes close to hand though thank you muchly.
ever herd the words "there is no such thing as RRP or asking price" sometimes yes you gotta fork out if you really want it, but 9/10 times you can bargain it.
Because the last time I was there it looks like one way ticket to defect. I dont mind sitting in colins car and park at mirage or something though. :P
Dunno if my car will even be there now :) Guys at beaurepaires didn't want to fix the tyre because it has cracks in the sidewall. Gunna try and get it fixed elsewhere tomorrow but I'll probably be there at Baskins in the Prado.
Yeah. From hagglers. :P
And it's not even like you NEED those rims. You're selling FOURTEEN rims. It'd be different if you'd buckled your rim and were short on cash and really in a bind and needed something quick smart. But that's not even the case. You just want them for nothing so that you can profit from it.
Fwah! Maybe drive around slack creek and check every tyre shop? There's an Asian one (tyre works no. 43 moss st) just across the road from autobarn which my friend knows the owner. Dont know if they will repair too but no hard trying. Tell him Colin Liu referred you to him.
Prado touge!!
let's see if we can get it up on two wheels! :P
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
