Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
yes tristan is my bitch...
do you know kenmore?
its in the same complex as kenmore woolworths, come along mogil road past indro under the centen hwy bridge keep driving past lexus up the hill when you crest the hill you'll see the golen arches (mikkyD's) turn right and follow the road around to the left and then turn right outside mcdonalds and you'll see nandos. hope that description works.
  MYY34 said:
Thanks for paying me out Tas for not getting outta my car last night, I told you I had a cold and it was freezing, I didn't wanna contaminate you and your friend lol :ninja:
You guys could of sat in my car BUT nooooo, you'd rather stand, hehe...
Nandoes x 2
why the f**k wasnt i called?!
bitch your my bitch!
pfft whatever, so long as we can spoon
Tris: you gotta keep your hands in your pocket.
I think I'll make my way there myself if its at Kenmore shopping centre. Hope I wouldnt be too late...
Shit... Imma give Nandos a miss... Wife practice starts at 7 so I'll only be able to make it after that...
Tris: if you're needing a ride I'll pop by your place and pick you up provided you're not having Nandos...
ps: can someone going please pte me their number. I only got Colin and Tas'. Cheers!
Edited by Brandon
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
