Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
yo sup?
Not much hey.. Still trying to convince this dude to sell me his wheels.. :D
He posted them for sale.. Now decides he likes them too much...
John, your a history buff right? Can you find me the quote from one of those Nazis (think it was hitler, but may have been goering or someone else) thats something along the lines of:
people will accept any imposition/limitation on their rights as long as it is in the guise of protecting the children
kthxbai
If you're still on:
"The state must declare the child to be the most precious treasure of the people. As long as the government is perceived as working for the benefit of the children, the people will happily endure almost any curtailment of liberty and almost any deprivation" – Mein Kampf page 403
Edited by Isola
So I'm probably a no show this Thursday. The car is hiccuping and hesitating like I have a leak somewhere. My other thought it that it might be my injectors, not sure yet. All fluids are fine, temperature is fine, but whenever I accelerate she hesitates and then goes from no boost to full boost, or struggles to hold boost (especially uphill).
I don't want to risk blowing something up, so for now I'm semi offroad until I get some fundage together to get the car looked at. That probably won't be until the new year thanks to the Christmas season sucking away all my money :D
So this also means I'm out for this weekend down the coast. And probably out from Wednesday/Thursday meets until I can sort out the problem.
sounds similar to what josh's problem was talk to him.
i sell you some wheels :(
It's fun fun fun... walking to work next week and you can probably count me out for thursday's too.. Not unless I can get a lift that way I can be drunk :(:D
Other john is the new guy, nobody cares :D .
:blink: awww awww awww awwww
you often seem to miss about the first 3/4 of the day :P
must be an unemployed bum thing, sleeping in till 2pm
I work part time and study full yet somehow I manage to wake up around 1-2pm during the week. Use to work 20hrs a day so i'ma sleep in as much as possible. Isola, keep living the dream!!!
I've had mine... pommie said he was gonna get them. Really good stuff for 11bucks. Beats KFC anytime.
Absolute filth comes out of your mouth Brandon.... :(
I don't eat seafood :)
Prefer the sausage huh? :D
Pm'd ya.
Anyone else for a good pm'ing... sounds raunchy
Side note : john idle's at 2000rpm
I'm starting to wonder if it might be your head gasket after that overheating situation you had... any smoke out the back when you rev it?
and to think u just got it serviced..
have receipts?
Yep sure do
I didn't get a pm. Wanna help fill my inbox?
Can do
don't know lets find out give me five
Yep sure do
Can do
Nope no smoke... receptionist gave me a weird look though as my car is parked right next to her window :D
how hot did it get jase?
doubt head gasket more like cooling system - lack of pressure, weeping radiator or split in hose. or as u said earlier pump and or thermo not opening but dans idea with the raditor cap sounded reasonable did u find one?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
