Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
how hot did it get jase?
doubt head gasket more like cooling system - lack of pressure, weeping radiator or split in hose. or as u said earlier pump and or thermo not opening but dans idea with the raditor cap sounded reasonable did u find one?
Hard to do that when im at work all the time :D Got tomorrow of so when im not sleeping i'll hunt around for one.
if you have receipts take it back to whoever serviced it
easy
Agreed!!! My theory with it is if your car has a new problem after it's been to the mechanics, take it back cos they may have stuffed something. Stuff can coincidentally break though in fairness.
It actually sounds like you're having a similar but worse problem to what Isola's having. A fkd fuel pump will give you a bunch of surging under load and the car will literally run as you're describing it. Was it just a general service that was done? I doubt it'd be a headgasket though. The symptoms are pretty obvious for it (smoke out the back, overheating, milky residue). As noobish as this sounds, it could be that they haven't connected a coilpack properly... I could be totally wrong though... Sucks either way mang :D
If you're still on:
"The state must declare the child to be the most precious treasure of the people. As long as the government is perceived as working for the benefit of the children, the people will happily endure almost any curtailment of liberty and almost any deprivation" – Mein Kampf page 403
Thats It! Thanks mang, you're a champion
wow ok jas pm received and im speechless
+1. That sucks the big one man
Even pm'd myself :(
LOL
It's fun fun fun... walking to work next week and you can probably count me out for thursday's too.. Not unless I can get a lift that way I can be drunk :) :)
Where do u need a lift from?
:P awww awww awww awwww
You have it coming if you don't turn up to baskins meets :) look at all the shit we give brandon
I work part time and study full yet somehow I manage to wake up around 1-2pm during the week. Use to work 20hrs a day so i'ma sleep in as much as possible. Isola, keep living the dream!!!
f*cking slackers
Absolute filth comes out of your mouth Brandon.... :D
+1
Prefer the sausage huh? :D
Absolutely :blink:
Nope no smoke... receptionist gave me a weird look though as my car is parked right next to her window :)
You stalker
If you see the PM list, its definitely not just cooling system
You have it coming if you don't turn up to baskins meets :D look at all the shit we give brandon
Hahha, I just thought you hung shit on him cos he's Asian. My ass is still being pounding by this assignment. Late submission ftw! But a no go for the meet....
ok ok everybody it's not the head! lol jesus, just wanted to check it out. no smoke though, so we're all good. Just was niggling at me as to a possible power loss after a couple of big overheats!
sif we're not racist...much
keep the chromies but only if they're less than 7.5inches wide. Narrower the better i say :D
The only thing those rims are good for is eating your dinner off . . . lol
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
