Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
any1 wana buy my Tein HR coilovers, been told very good for drift and circuit cars,
i neeeeeed monies so if you or your mates or your mate's mates need coilovers tell them to check thread
http://www.skylinesaustralia.com/forums/Te...rs-t299161.html
rarrrrrrrr whats everyone doin tonight? Considering harrys/chapel hill but I can't be up late tonight so trying to work out if its worth going for the hack all the way over there :D
No. You tried to change Thursday again, and everyone ignored you. Again.
:D
Erm... no I didnt. It was colin that said Lobster > Baskin... like I said, I've had me earlier on the week.
Idling around 2000rpm!??!?!?!?!
Tristan: That tacho reminds me of mini...
John: Get back to your assignment and get your arse to the wash tonight! Quit slacking!
Oh yea. Its Harrys night again this Thursday. If you're gonna be working around the northside (Thristian), should we just make an exemption this time and go up north instead of icecream! Chicken Parm FTW!
Erm... no I didnt.
Don't lie to me Brandon. It's like playing with my emotions. Which are already in a fragile state with the car playing up :D
Not gonna happen dude. Still getting pounding by this assignment. Ass is quite sore
John: How much you want for that fuel pump? I found out that it should fit fine :(
Not sure what they're worth second hand? $40 and some cupping reasonable?
Dave sold me his for like $10
Lol, there you. I've seen ppl sell silvia ones for 60-70 and thought 40 was reasonable for an r33 one. When it comes to forum members I'd seriously hate to rip them off. $10 + cupping and it's yours Isola :( . I can help you put it in too if you want, but that'll be more cupping
thats cause im the nicest. on another note... do you approve josh? finished 1 side 1/2 way through the other.
also got a question... pods or no pods?
and yes i decided to run the skirts, they look baller. :(
Now that sounds like a deal that can't be beat! And when would you be free from your hectic assignment life to assist with said install?
Well looks like I'll be getting raped for the rest of tonight and tomorrow by uni. Saturday I'm going to the drag day. Sun, mon and tues will be work which means Wednesday at the earliest.
hmmm... might have to tackle it myself then. when can i come get the pump. and from where?
Time to come down south! John lives just 5mins from my place... Hahaha.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
