Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Josh I have a 70k deposit, find me a townhouse with 3 bedrooms and at least one garage plus visitor parks that i can steal
for 70k down, I can get you into a friggin New Farm place, that would be the envy of most.
But serioulsy.. If your not dealing with other agents, I can just act as a buyers agent on their stock, in the area's you like.
Costs you nothing, my duty of care is with you and not the seller, therefore you know what I know about the properties in question.
Joshwe are pretty much looking for the general area we are in, should be plenty in Fairfield, Yeronga, Yerongpilly, Annerley and Moorooka perfer to keep repayments around 550 to 600 a week and close to some form of train station or decent bus route would be ideal (no parking at my work :ninja: )
i have 34.25 working hours left
might have to plan some field trips and spend half of that driving around
Working hours left for me would be about 8 or 9. But will actually be about 1 or 2 probably :ninja:
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
