Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Got my car back together with stock exhaust manifold on. Noise is gone and it goes like the clappers again, so I'm calling it fixed (y) :)
Wound the boost up to 12 PSI :)
Now just got to chase up the seller about this non NEO head
Nice
now I know 2 people with rotisseries
is the other persons better then mine, cause crap wish i could of borrowed. lol mines fully backyard arc welder styles. its not much to look at but should work. :blink:
keen to come look at a 4 door chassis with me today? its at logan, need to to repair my car and tristans :D
Edited by 32_Dave
is that tubing thick enough to hold the weight of the car without warping? i can't see how thick it is from those pics. Also I'm assuming you got the pivoting points exactly the same height from the ground and also left enough clearance for half a car to pass under the pivot?
its old veranda railings about 4mm thick. 50 OD. its heavy shit. there both same height, and yes there car will rotate, its abit shorter then cars width, because when u rotate the diam gets smaller or some shit. i fail at maths. buy it'll work. its f**king high even with the chassis on the trailer its gotta go up 500-1000mm. Should work. it also has a steel tube that links the two stands, allowing no movement. got allt he ideas from this site. http://www.mts.net/~hpokrant/Restoration_T...serie/Plans.htm
funky u cud have helped..
but u were like f**k this shit - im bailing!
no
ps - funky u in melb or sydney atm?
melb, at home now.
its old veranda railings about 4mm thick. 50 OD. blah blah...[/url]
sweet man, plans look good... pics of it in action plz.
in other news... i think tas likes my R32 after a quick fang out last night.
also we went to Haci's and had EPIC kebabs the way they're supposed to be made. Tonight is a duck meet with some of the local SAU boys (like you guys, but from Melbourne).
ah - and to think he was all SR
finally he remembers what an RB feels like under the right foot
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
