Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
alrite mate, thanks for the help, im gona get the car tinted first, then i might follow the tutorials and clean the headlights up and buy the HID kits needed , the series 3 headlights would be the easier solution but since they retail around 2 grand a set, cant justify that kind of cash, have been looking around for second hand ones to pop up for quiet a bit, no luck so far,
but thanks anyway,
S3 look nice but HID would be alot cheaper way to go and they're right you will need 2 sets 1 for high and 1 for low and LED's for the parkers which is like $10
and for the HID's i recommend getting around 6000-6500k i have both 6500k for low and 8000k for highs and i find the 6500's a lot better
and if i ever show up to a meet (may be thurs unless something comes up) you can have a look at it all
I thought the same thing. Plus I'd get shot if I brought it home... and not in a good way!
fine :D ignore my post :P
I didn't know scouses were such cock donkeys :)
Done!
Somebody has their panties in a bunch. I ment to reply to you but for some reason it didn't bring your quote up in the reply box so I just forgot about it lol.
Multispokes ftw. Those are the Work 11R??? something or other aren't they? They're pretty much a copy of the SSR Type Fs. Have a look at the SSRs they are so freakin sweet. I wanted them for the GTR but $$$.
morning mangs
Morning Mang
What's crackin?
Morning Mang
What's crackin?
Not much mang. Sick of work after 3 days back :). Figured out I have another 3 weeks of holidays I can use, very tempting... :D
Good Morning Peeps
John: I think 6th is when the gearbox arrives and I doubt he'll have the car by the end of the week... Hahaha!
Morning peep.
It takes a couple of hours tops to do a gearbox :) (in a 31, if GT-Rs take longer than this, they must be rubbish :P)
Mangs.
Farken hot yesterday.
Wasit?
first day back,
F-my life
I dont know if the gearbox is the only thing he's got on the list to do, its just worst scenario. And he's got a tune lined up too. From memory, EFI is only open on alt Sat.
Oh yea. Just got notice today to get my site clothings! Looks like I'll really be heading up north in a fortnight's time. Woohoo!
A GTR gear box for Dan is pretty quick, the man is a machine he did my clutch swap in like 45 minutes but that was a GTST so at least double it for a gtr!
how could they have ever considered dropping him hey?
Should just put him back down the order where he used to be: he's brilliant at this job where he has to bat with the tail in a tough situation
Phil Jaques deserves to be back in, his last test innins was a 100! However with an eye on the future i would consider Callum Ferguson, i think he is on track to be very very good
    • Well, if it wasn't a GTR I'd say that killing an RB is a perfect opportunity to put in a proper engine. In your case, proximity to Brabus and AMG V12s would be a no brainer for any RWD Skyline engine death event. In my case, because my car is my daily, anything that I do wrong that means I have to do it again is both an absolute pain in the arse (simply having to do it again), and also a doubling of the pain associated with having the car off the road to work on it. I would class a botched head gasket install as not being "engine death causing". More a case of "f**k it's still leaking!"
    • Yeah, this is more stuff like transmission/clutch R&R. Intake manifold R&R. It's not super complicated, but each step matters and you need to be careful and patient. I have heard stories for example of people not figuring out the super coppermix twin plate orientation and getting it wrong on assembly. Removing a cylinder head and putting it back in once it's machined isn't that hard, following torque sequence to install some cams isn't that hard either, but somehow I've seen a lot go wrong between here and there. Scraping off all gasket material isn't that hard either, but I've seen shops ruin heads by using a roloc disk that was too aggressive.
    • There is some shops in Germany that have quite a bit of experience with JDM performance 4-wheelers. I think if it actually comes down to it I'd let one of them do the head gasket. Killing an RB26 is too expensive a risk just to save some money by doing it yourself.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
