Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Mangs
Yesterday someone had ( i assume ) stolen some silicon tubes and guns from some workers ute and proceeded to fill all the parked cars door handles and locks with silicon. Lucky mine was in the garage.
Mangs
What is it with you and silicone? I'm starting to think you're doing a Tyler Durden... You're sleep walking and being the silicone bandit!
ha ha i just did my bmi, i would need to be 81kg to be 'healhy'....when i was playing rugby seriously i weighed 90kg and was 8% body fat. I cant actually get anywhere near being 80 with out being anorexic, BMI is the biggest joke ever
To weigh that much i would need to shit out my skeleton!
90 kg is pretty much the lightest i will ever be, if you go by body fat percentage 8% is too little so if i got back to 90kg i would be about 8% fat again so i would hate to see what it would be if i ever made 80kg! Right now i am in the healthy range (just) for body fat percentage but almost obese by BMI
Surprisingly no shitting from this food poisoning... Pure puking and like 7 or 8 times (lost count) and no food for 2days.
Maybe everyone else got heavier bones?
Oh and Yaface, that GTR looks ok the price is good and the R34 engine is a minor upgrade....but check the engine number in fast it way be any old RB26 just with R34 cam covers, also that colour sucks but thats a personal opinion and none of the standard R32 GTR colours are that interesting
Yes it is. I have to be under 80 to get into the 'healthy' range, which is just BS.
I think I fall into 'fat bastard' territory too :)
Don't we all?
How do you figure out your body fat %?
UPDATE: standard clutch is nearly toasted on the GTR, so ordering a new NPC clutch with Dan, i budgeted for s**t to happen but not s**t this expensive lol, oh the wonders of the skyline/GTR ownership, well hopefully shouldnt have to replace in quite a while, and im suprised standard one lasted about 80000Ks lol especially since i learnt driving manual in the GTR haha, if i had a car a few more days the clutch would have started slipping about 5mm of meat left on it, big thanks to Dan for going over the car and noticing it,
We have scales at home that send electrical current i think up your body and it measures the resistance, giving you a fat free mass %, water mass % and fat %. there is some old school way involving pinch tests but finding a electrinic scale is easier lol
does it hurt? :)
*hits up ebay
*sigh* Yeah... I guess so. Must be all the KFC :P
I blame colin, he made me double my nugget intake!
Adam get one like this...its awesome, and from NPC it did cost over $2000 though :) but that said it drives nicely on the street and i dont have to worry about launching as its the one Mark Jacobson uses!
Martin, no pain at all! It might not even be electrical current but you do have to shand on metal plates with no shoes on! we got ours from the good guys for like $100
hey bro, i would love to get the nismo twin plate, heard awesome things about them, but the sad truth is i have now spent nearly 7 grand on the car and thats not including the clutch, it hurts me because all i needed to spend was about 3 or max 4 grand, the rest was all things i wanted not things i needed, Dan recommended the heavy duty clutch from NPC, the one that replaces the stock clutch, he said it would be strong enough for upto 280awkw,i dont know if it will be able to handle launches etc
and im calling it quits for now, once this stuff is done, all im gona do is service it, ive spent way too much money on things that werent needed and that money could have been spent elsewhere,
-FML-
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
