Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
where at northside you slydog?
I will be at petrie
I think u balls'd up the date there mang
I just had an idea involving my fridge and a gurney... am I a crazy person?
Chalk has mad food! I'll never go there for a drink though. I'd need to remove my shoes, lose some teeth and fk my sister to fit in with the crowd there on a fri/sat night
Friday and saturday nights are ok, and sunday afternoon is great, during the day is when it is dicey because all the deros are there playing Keno
clutch arriving tomrow morning from NPC :banana:
gearbox cat and front pipes will be put in as soon as clutch is in,
just talked to Rick over at EFI and sorted out the tuning and what i want,
good bloke he is :)
response and fuel economy over powa will be tuned at 0.9 bar,
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
