Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
its not that different to yours... you just need more wide, more low and more epic fitment.
i don't give a rats arse if they have angel eyes or not... I need an HID that comes with a lens that's less than 3" diameter and is able to take a H4 dual beam.
so I can put it in this:
sorry, but epic FAIL
wonder how vicroads wud like them...:ermm:
vicroads will like what I let them like. pretty much all HID's are illegal anyways, cos they don't self level... so meh.
oh look out, its Dave, master of the universe and all that is R32s. Get back to me when you have one n driving condition sunshine.
wow, u woke up on the wrong side of tas's bed. its an opinion champ. no need to bite my head off :ermm: as for driving condition... one day.
tas' bed's in QLD and I'm in VIC. logic fail. lol.
if u took a more positive attitude on the subject i would be more inclined to suggest the right item for you..
eh?
ps: thanks for the heat wrap :ermm:
no worries, it was bought for you specifically, not found at the workshop as tas might have mentioned.
speakin of which, i gotta go back to the shop tomorrow and change those headlights over.
more people should be like that. you help me i help you. :ermm: even if you just found it its still kool, saves me cash on the proj.
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
    • Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
    • Probably. But keep in mind that all Joshua was saying that because of things like timing scatter, and many other related and unrelated things, tuning too aggressively should be avoided. Hence why both he and I said that fitting the cat shouldn't cause you to suddenly fall into the danger zone.
    • I’m running links ecu and an upgraded crank sensor. So I guess I have less chance of this.
    • The stock Nissan CAS gets very messy at high rpm, particularly with bigger cams/springs, and most aftermarket ECUs don't do as good a job of filtering the noise as the OEM ECU somehow manages to do. So you get "scatter" in the timing signals that can be really destructive to the ECU's knowledge of engine position. And so you can get spark firing many degrees early, leading to catastrophic detonation events.
