Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
cheers, I always lol when people think that an s13 is in some way slower and less capable than a r33
That's unfair though, 33s are boats.
S13s certainly plough a field better :)
they're a good engine, shame about the noise (and lack of cylinders)
yeah the noise can be ok with bigger turbo and decent exhaust, the more its muffled the worse it is lol, will never sound as good as a RB though...as for lack of cylinders pfftt 86mm x 86mm goodness, its the goldern ratio for revs vs torque,any more cylinders and you would end up with a silly little thing that doesnt make peak torqe till 6400rpm! :)
I love tractors now, i am seriously considering ditching the GTR when its rebuilt and focusing my efforts on the sil80
tristan likes this a lot, a hell of a lot :)
yeeh will never be as good as rb - but can sound tasty, oh and epic sr flutterzzzzzz
:) i was joking
dave and i just re did my zorst to sort out all the epic leaks - we used that high heat gasket goo and gaskets
Don't spose you know what the standard "3inch" gasket part number is? I CBF tracing the flange's and taking it in to super cheap
dave has it :)
does this mean the junker is coming out? not out of the closet - just out thursday?
dave has it :)
Depends..
I haven't order'd a de-pu$$y pipe yet, because I dunno if it well sell today on ebay, plus i CBF fitting the front pipe myself
I don't bother with any gasket goo or anything with exhaust gaskets...
just go into rapeco and ask for a standard 2 (or 3 if thats what you need) 3" exhaust gasket. They'll find it for you. Or an exhaust shop
Depends..
I haven't order'd a de-pu$y pipe yet, because I dunno if it well sell today on ebay, plus i CBF fitting the front pipe myself
i opted to be a pussy instead of getting a de-cat :)
i like that you're keeping it hahaha :) (or at least thinking about it)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
