Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Call them hoebags and go off. They won't take you seriously unless you make a complaint about the service. They'll do a line test and then get you to mess with your settings. What modem you using? Dlink by any chance??
Dlink G604T or something like that.
No, one carton of XXXX and one of carlton :)
You shouldn't filter the line that the adsl is on...
If you have a 'splitter' that has an input and 2 outputs (one that says 'phone' and one that says 'adsl' or 'modem') then that's ok, just make sure you use the adsl/modem one. But if its just a plain old filter (one input one output) f**k it off, it'll be filtering out most of your adsl bandwidth
Nah its a splitter thingymabob with the two outputs and it is plugged into the adsl one. Was thinking it could be shitty phone lines in the building as it's 20+ years old. But still going to call them today.
secret drift morning session this morning
Side on pics so I can see these f**king wheels ffs!
have decided my car needs more epic downforce.
which one will provide me with the best results?:
Roof spoiler is the only way to go tbh.
Dlink are cr*p :). But I think theres another issue at play here.
Goodo.
Try going to http://www.speedtest.net/ to test your speed. Then see if you can find in your modem the line attenuation and noise, and synch speeds and post them up for me, along with the speed test results. (Make sure nothing else is smashing the internets when u run the speed test, ie torrents, etc).
They are teh sex
+1
well 260kb is about right for a 2mb line speed. But if you are that close to the exchange with ADSL2, you should be getting closer to 20mb line speed and 2000kb download.
Wots ur address (PM me if you like)
2930 Gold Coast Highway.
Yeah, you should really be getting 10x the speed that you are.
According to TPG maps:
Line of sight distance: 231m. Possible cable distance: 393m.
So basically, you are next door to it :P
i got this apparently its average
Yeah thats about what I was getting at St lucia, hope to get a lot more now because I'm closer to the exhange (although not as close as colin, about 600m line of site for me, 1-1.2km cable distance)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
