Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Horny weasel, nahrung is indeed food!
ah, weasel. of course.
Yes, I figured as much. I would have said "trinken Sie Bier und essen Sie wurst", but only because that is the only german food word i remember...
how do you "tell" a person a spare "wiesel"??
LOL. No Jase, I don't need you to tell me a spare weasel.
busted :)
sooo bored at work
Never been to the german club. Is it good ?
Its great, food isnt as cheap as it used to be but its tasty and the beers are awesome, Erdinger on tap FTW!
I haven't seen any busty beer wenches there unfortunately, most of the bar staff seem to be dudes :D.
There are a couple of v. nice waitresses in the resteraunt though :)
Theres a few good beers on tap, and a sh*tload in bottles.
aren't you supposed to be at work?
yep :)
There is a place on bunya ave that might have a injector for you cheap. Just can't think of what they are called.
injector or coil pack?
when's work?
coil pack you know what i mean.
work ? now apparently.
i can get you some goo stuff that will insulate it if you like. can get it today
That'd be awesome if you could. The tape stopped it a little bit, but not completely. When I took off from Coles last night I hammered the throttle and the car nearly died! It was like driving a rotary with more than one person in it :)
I did some limiter bashing on the way home though to make sure my red lines were still ok. Still gets up to 9, so it's not suffering as much. Steep hills aren't killing it as much when I put the power down now. But it's still SLIGHTLY laggy. So better insulation is probably not a bad idea. I am just so sick of ripping all that shit out to get to the valley :(
Fire!...good...
You're just saying that because you want me to need water to put the fire out...
I am just so sick of ripping all that shit out to get to the valley :)
Leave the valley cover off
Yep it's my cunning plan.
I'll get some goo for ya john.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
