Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
yeeeh -it'll be fun tehe
.........swap cars M :rant:
hey?
:P
haven't you got yours back yet?
haven't kept up with the posts. didn't have the net for about two weeks (since i saw you guys last on thursday actually), so am a little out of the loop.
just got the net back this morning, and have dedicated the arvo to pwning newbs on counterstrike :D
it's a rich life i live...
:P
just got the net back this morning, and have dedicated the arvo to pwning newbs on counterstrike :rant:
i got mine back at the start of last week - just figured it cudnt hurt asking again hahah :D
rich life? i had planned one - but my numbers didnt f**king come up :dry:
coming thursday bud?
My game is at 9:20, so might fill up on ice cream and then make my way out to the game.
i will try to convince you guys that a cruise to carina instead of sunnybank would be farken awesome.
Thanks Tacio matey for tonight you are a life saver.. pizza's tasted great gf even loved the pasta!
picked up the coilovers.. the fronts are pretty much brand new rofl.. but has different camber tops on gonna remove them later.
tommorrow night! braided lines!
easy az mate. after u left that place caugh on fire! perfect timing :P
so now, u got two sets? whats wrong with vamber top? hell of a good deal one way or the other!
The advantage of the TRUST ones is that they have a thermostat, which allows the oil to get up to temp faster so you are not driving round with cold oil all the time.
I am not sure if those coolers dave and tristan got have a thermostat or not but I am guessing not. And they probably need one, they are f***ing huge
yeah so i've read.. oil designed for high performance has quite high viscosity.. there is where the in-built thermostat comes in helpfull.
these big coolers MUST have thermostats..
You are correct good sir. You can buy aftermarket inline thermostats to add in to the cheap china kits, but by the time u do that it might not work out much dearer to just get a TRUST kit in the first place.
found a vid of tas at a karaoke bar...
Here i thought my audition for Aus Idol was going to be kept silent..
Mind giving a "Please exlpain" on what you was doing at a kids party??
i went on a date with that pirate girl from HJ's. i put it in her ass that night. it was worth dressing up as ghetto superman.
AMEN!
i gota get me one of those
ahah hey look its shan !!!
tas let me know if u need a hand with ur car. happy to help
tristan bad luck on that shit ay. s14 drifta lost his licence recently so feel betta.
ill ask my dad about oil / oil coolers, as he has worked in the oil industy for 20years, never ask him questions tho if ur in a hurry, bring a sleeping bag and a tent cause hell be ramblin all night.
finished making my mount for hydro today, tacked it in...
its rolls back under in a triangle shape, its rock solid :) even when i just bolted it in. reeef reeeef skid skid
seeyas all tmoz night, can come out late taking friday off.
did a lil work on the S14 today and untacked the roof skin. thinkin of just replacing it with lexan... hmmm. failing that i'll just put a non sunroof roofskin on the s14 and swap the sunroof over to the ceffy.
racecars don't need sunroofs... right?
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
