Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I say someone should buy the Lotus Exige Cup 260 we have at work
260Hp toyota 2zz supercharged engine and only weighs 760kg or so, time attack will rock
You got the keys :)
dont worry dan, we were meaning - for competitive time attack, an r34 gtt would be usless
we <3 your 34 :)
Yeah I like 34s, but big + heavy + 2wd does not a good corners car make
$5000 if you deliver
Mannnnnnnngs
Mang
Thats a massive call
Theres quite a few rwd cars in the 2010 holy grail
Sure when talking lines awd has traction advantages in some areas though they are over 100kg heaver than rwd
e.g. You could buy a 34GTR for 40k which is about 244kw & 1540kg or a 34GTT for 20k which is about 206kw & 1410kg then spend 20k on it, strip it an youl have 300rwkw & 1350kg
If I were to buy a Lotus it'd have to be an Esprit. Can you get me one for say.... $50?
Now where did I put that 100k? I swear I had it before...honest. My credits good right?
Esprit = Vomit.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
