Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Farkn lol
I think that makes more sense that what you usually say.
Morning mangs.
I won't deny it.
Morning to you too *tips hat*
oi ravbat, i <3 you
<3
ps, guess waht song is on channel V right now?
il give you a hint...
SSHHAAWWWTTTYYYYSS LIKE A MELODY IN MY HEADDD
BEST
i <3 memories by david guetta/kid cudi
ALSO BEST, MORE BEST THAN PREVIOUS BEST, SO THEREFORE 'BEST'
Ugh so not looking forward to this, i hate going to court, If i was judge dread i wouldnt even need to go, my refusal documentation would be accompanied by a loaded gun for them to use on them selves to save me the trouble of coming round and administering my refusal in person!
4000 posts = best?
Its over 94000!
Do it the Chuck Norris way. Roundhouse kick to the face.
i dont get it..what happened?
Your doing it wrong.
I will have to go to court for work stuff AGAIN, Any time someone appeals a decision or is fined for compliance matters we always end up in court
Tas, do you realise you come across as a total douche in just about EVERY post you make on here?
However, I think in this case he's actually right boys:
The building '620' is where baskins is.
Good poasting. Further enforces Rules 1 & 2 :D
I thought that was me ? :D
How'd you get access to BCC stuff ? :laugh:
naaaahhhhh, you come across as a mad kent :D
On the internets...
Yes... the illusion is complete
How many internets do you need ? I only has three. :laugh:
Lol rightio lol i think ive lived in that house more then u been a cabby mate
What's that got to do with it?
Unless they change the boarders in last 3 years i do not believe what u say is true! :D
It's been the same for a very very long time
Actually, you just proved what I said. Here's a closer look at how that border line actually works:
As you can see - the border lane runs BESIDE the road, giving everything on that section of Moggill Rd a street address of Chapel Hill (including Baskins, represented here by a black dot). Everything behind the line is Indooroopilly. If it were on suburb on each side of the road, it would look like this instead:
Edited by Isola
I rest my case
Is your case tired? :D
I'm off to uni hurrah. SUPEER GREATOO TRAIN TIME!
But yeah Martin I thought you had to pay for access to those suburb maps? I tried looking for em but my googling skills were inadequate.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
