Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
I'm afraid this proposal is unacceptable. Allow me to point out the following:
-She is too young for skins
-She is too white for you
-I have a black belt in being awesome
Therefore, she is mine. QED. TFC.
If you have any doubt as to the validity of this argument, please see Rule 1.
That is an interesting argument. However, I put it to you sir... :cool:
you know the rest :P
No german club for me. Mates 21st tomorrow so I will be getting wasted there. :blush:
back to the m-spec debate,
im 98% sure that there is no such thing as an "un" m-spec r32, im pretty sure it was just a smart marketing scheme implemented by nissan when they first released the r32 gtst
Give the man a prize :blush:
For those who are interested in the legal theories that i was talking about at the meet last night here is a link that properly explains the 'Chewbacca Defense' :blush:
EDIT: Lol linky http://en.wikipedia.org/wiki/Chewbacca_defense
o rly? maybe if they're nice and common it's ok to cut into mine then... hmmm
Edited by Isola
Ya Rly. All GTSTs were Type Ms. Chop that shit up :blush:
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
