Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
ohk well i have a z32 AFM chillin' in my room, however bigger injectors + ecu = $$$ fml
alright well i guess ill give old dan a bell and hold my ankles
what ecu does it have now?
And a noun. And a prefix.
Is it in the dictionary yet?
ohk well i have a z32 AFM chillin' in my room, however bigger injectors + ecu = $$ fml
pain mang. Can you use second hand gtr injectors? that would probably save some money.
nah, stock sr ones are almost the same size as gtr anyway! s14 are 440cc and s15 jdm are 480cc
the ecu, which was thought to be stock - turned out to be an aftermarket one of some sort, a japanese dr drift sort of thing - im not sure on its maps etc
Well in that case i wouls assume that tuning is more than likely the culprit, I thought you had it tuned already when i gave my other suggestions, first port of call tuning, injectors to small ect can be tuned around, but i would be concerned for my engine running unknow tuning and experiencing hesitation, what was the cause of the last failure? The ecu could have had somthing to do with that engine dying too
yeh - the guys who sorted out the timing discovered the ecu. the dyno run to sort out timing was included when i bought the new motor - so no "tuning" went on
alright well ill turn the boost down in the mean time and try and get it on the dyno
sounds like a solid plan!
Might as well chuck on the z32 (just)before the tune too
PS! JOHN!
did i see you post a link to "secretdick" on the last page?!?!
WOOOAH
you've changed man, but im not complaining ;)
Indeed. I'm like an epic classifieds lurker these days :)
Or a pimp 33 4 door...
mmmmmmm rolling sechs
Tristan you should talk to Dan at ERD, he is pretty sick at over the phone diagnostics, just dont take too much of his time cause i want him to finish my engine :P
I really have to remember to call him about an attesa filter one of these days
someone just replied saying AFR should be checked out and therefore needs dyno time
he also said 1 bar is too high on stock injectors/afm
ugh GAY
Thought you had a Z32 AFM? That'll easily hold 1 bar mang
He has some experience with SR's, he is the RB guru but very good with SR's too
but if he suspects it is sensor or elec problems he will likely send you to EFI, which will make you cry, because they have an ocilliscope and he doesnt
Going to EFI would even make baby Jesus cry
Oh, I have a "thought to be stock" car too, but it just keep throwing me goodies and surprises! I want to check my ecu, and do a dyno run. Just to see what's really inside it.
ah the joys of my car :(
+1 for every other bastard in this thread
This 'splains Z32ness
yeah... in your room will help. Now you can run like 2 bar through your desk. Win.
Put it in the damn car and get it tuned :)
PS don't remember seeing it - but did anyone say fuel pump? Is that still an old one? Or has it been replaced?
PPS there was like... one whole page just about dongs. Not a bad whoring effort, I must say.
yeeh john i have a z32, but i didnt fit it up - guess now im going to have to hahaha
joy!
Fit it and run it and see how it goes. Might go ok, might drive like a bag of shit and need a tune, but you might be lucky and it'll just run.
yeh bad idea - itll run like a total ballsack ive read
and yeeh i have a new fuel pump
and yeh my desk runs wicked boost and flutterz hektikly :)
aww really? :) that sucks. I was hoping he might fluke it
It *MIGHT* be OK for just babying it around for a bit, although its highly unlikely.
Is DEFINITELY a bad idea for driving it hard/pinging of limiter for drift. The mixtures are going to be wrong, and most likely they will be lean. Turbo engine + lean = splode
hmm... this is very true.
damn... well... get it fitted and tuned son!!
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
