Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
There are no such thing as real and fake semi slick tires.
Essentially anything with a softer compound with less tread blocks then a “street” tire, creating a more flat area for contact on the road, that is/could be used in motor sports is a semi.. Obviously marketing loosely uses the term in brand marketing, however.
Khumo KU36, Federal 595 RS-R, are basically just very sticky street tyres with a few less grooves on them, but are marketed as 'semi slicks'
Compare that to the likes of Toyo R888, Bridgestone RE55, etc which are proper motorsport tyres. The grip levels and behaviour of the tyres are going to be quite different.
little update of what i've been up to all sunday / this arvo before seeing bruno... f**ked up shit.
welding done by yours truly....
gotta check up PCE on my fmic kit.
Sure they are. they are still a semi however.
That's like me saying I believe the Advan A048's to be more of a semi then the Toyo R888's as the "the grip levels and behaviour is different". Which is the case with the Toyo's and Advans..
Big jump in price, as I'm sure we all know.
I guess my main point is tyres designed for motorsport compared to tyres designed for the street. But whatever, its not worth arguing over.
If you run street tyres on the front and something like R888, Re55, A048 on the rear, it will be very unballanced and understeer like a dog when the rears warm up. I know, I tried it with RE55s on the rear one track day.
However, if by 'semi slicks' he means something like the federals or khumos, he can probably get away with it.
with josh? no it probably isnt..
*thinks back to baskins and robbins incident..
:blink:
Seeing I’ve been involved with competitive race cars, probably not.
I’m not sure why anyone would be running a street tire up front and a semi on the rear. You could get away with a semi on the front and a street on the rear, however again not sure why.
I personally am not a fan of mix and matching tires
hows your anti-baller offset treating you josh?
coming out thursday?
Pretty sure I hate narrow wheels.
I might come, depends how I feel. I've been going to bed at like 8:30pm haha
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
