hey just got to 2 questions
number 1
i wars thinking of making a rb20det with 500bhp to start with, becourse not many people have done it, and to see if it can be done. so if you have an idea to what parts i should use it who'd be great. i am going to use a HKS f-con v pro engine management.
number 2
is it even possible to run 2,2 bar of boost on stock internals, becourse there is a man in sweden that clams to run 550bhp and 2,2 bar of boost, here is the specks.
ported head with custom cams.valvs
stainless steel exh.manifold with T70 Turbo
700hp + turbokompressor.
HKS 60mm wastegate with screamer pipe
Jun style polished inlet manifold with 90mm billet trottle
Bosch 1000cc injectors
twin Whalbro fuelpumps
modified fuelsystem
GTR style large intercooler 3# pipes
Link Engine Managment system
water/methanol injected to support the 98oct std pump fuel
when going over 2 bar of boost
HKS ignition amplifier
Nos system
launch control/antilag system
sorry if my spelling is a bit off
Edited by larsgtst
https://www.sau.com.au/forums/topic/261284-high-power-rb20/
Its pointless. A waste of money. It will be lag city like no tomorrow. Youd be better off going RB25. But if you want to do it, then do it.
2.2 Bar on a stock bottom end...you can try it, but dont expect it to last more than a couple of dyno runs!
Ive heard of someone running 2.0 Bar through an SR20. Its crazy!
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4479997
here is a pretty crazy rb20 built by OHperformance i had on the dyno the other week the revlimit was 9800 and sounded sweet, real credit to the guys.... :) 490hp at the wheels.
Edited by URAS
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4480124
it must be mental from 5000rpm to 6,000rpm!! lol it triples it's power in 1,000rpm! does it still make power after 7500rpm?
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4480168
there is a reason not many people have 700hp turbos on RB20's... did some people go on school holidays early?
T70 turbo sounds like a piece of shit http://www.skylinesaustralia.com/forums/Eb...bo-t130247.html
5000rpm of lag does not sound like fun, IMO, if you want that power, RB30DET or a turbo LS1 :)
Edited by Ryan1600
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4480335
femno: i know that it is better going for a rb25 but here were i live they have some strict rules about engine swaps, the only way i can do it, is if the people that decide if it is going on the road or not, cant see the difference on the two engines.
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481018
They have strict rules about motor swaps...
Yet you can make the motor you have into a 500bhp item?
Sounds like laws there are dumber than here in Victoria, and i thought that wasn't possible.
500bhp would be about as useless as 1000bhp from a OS 3ltr :verymad:
Whats the use of the car? You would get far more enjoyment, speed and so on from a RB20 that has more response.
Such lag that would require would make the car slower
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481060
i am going to use the car as a every day car in the summer.
if i remove the cover over the plugs so they cant see on the cover if it is a rb20 or a rb25, but is there any other way they can see that it is a rb25, and not a rb20
Edited by larsgtst
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481127
If you buy an R33 RB25DET it is easy to pick the difference as the inlet cam gear looks completely different and the inlet manifold is clearly different. Get an R32 RB25DE and turbo it, nobody can tell the difference externally. I was going to put 25 internals in one for a cheater RB20 but am happy with the 340hp at the wheels my std RB20 makes so sold off the engine, rods, cams and pistons etc
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481575
300rwkw+ & RB20 in my book does not equal alright for a daily driver :P
250-270rwkw & RB20 IMO is about the limit, otherwise you just hurt resposne too much to enjoy it and you have to drive with your foot up the car everywhere you go
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481695
here is a pretty crazy rb20 built by OHperformance i had on the dyno the other week the revlimit was 9800 and sounded sweet, real credit to the guys.... :P 490hp at the wheels.
Sorry to go off topic here but you wouldnt happen to have a video?
Would LOVE to hear it!
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481849
i Dont know Ash, 4 years ao people said anything more then a 2530 and 220rwkws was too much for a std RB20. A new manifold and some different turbo combos are getting thrown at Ben and we will soon know where we land, it will be between 260 and 310rwkws somewhere. Just have to find the combo that works best, cant wait to see if the std 20 can handle the extra power and more importantly revs :D
...walks off and starts singing "anything an RB25 can do, and RB20 can do better... :P
https://www.sau.com.au/forums/topic/261284-high-power-rb20/#findComment-4481943
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
